Author [NL] [FR] [ES] [DE] [SE] [IT] Crash Bars by Tralex  (Read 36548 times)
  • Offline Pauli363   00
    • Trophy Pro  ‐    169
      #160
    Offline Pauli363
    • Proud owner 2015 Triumph Trophy SE in Black
    • Bike: Triumph Trophy 1215 SE
    • City / Town: Glenavy, Ireland
    • Country: 00
    Re: Crash Bars by Tralex
    Reply #160 on: Oct 24, 2022, 05.33 pm
    So before dinner, I decided to mount the rear pannier bars.  So easy, literally took me 30 minutes.  Probably mount the front horizontal bar tonight and that's it.  When the plastics are back on 15 minutes should complete the job.
    • Trophy Pro  ‐    169
      #161
    Offline Pauli363
    • Country: 00
    Reply #161 on: Oct 27, 2022, 07.16 pm
    So.  I have fitted the front bars as well now.  I had the fairing off for other work, but it was not difficult fitting these, probably an hours work.  3 bolts to undo, and just 2 allen bolts to put on.  Looks well too and seem very sturdy.
  • Offline ChiefMn   us
    • Trophy Member  ‐    25
      #162
    Offline ChiefMn
    • City / Town: St. Paul
    Reply #162 on: Jan 23, 2023, 09.11 pm
    Can't get the cross bar to line up. Does the long side go on the left or right. Can't tell from the video. Also found the gas tank mount bolts were not located in the holes after my 10,00 mile service at the dealer,which was the start of my problems
    • Trophy Pro  ‐    169
      #163
    Offline Pauli363
    • Country: 00
    Reply #163 on: Jan 23, 2023, 09.20 pm
    Can't remember, but if you are still stuck tomorrow I can go out and check on the bike.
    Best way is to mock the crash bars up.  Loosen the lower bolt at the bottom of the engine block.  Then mount the left and right crash bars temporarily on the lower fixing points.  You should then be able to match up the upper mounting parts with the crossbar.
    Its important you use the two metal bars in the pack to ensure you have the crossbar situated at the right angle.
    Not sure what you mean about the gas tank mountings.  The crash bars don't go anywhere near the tank mountings as far as I remember.
      #164
    Offline ChiefMn
    Reply #164 on: Jan 23, 2023, 09.42 pm
    I installed the cross bar and used the supplied gauges to set the position from the bottom of the tank to the bar. Doesn't do much good if the tank isn't bolted in the correct position
    • Trophy Pro  ‐    169
      #165
    Offline Pauli363
    • Country: 00
    Reply #165 on: Jan 24, 2023, 12.51 pm
    I think you have answered your own question then.  You will need to sort the tank location out before you install the bars.
  • Offline Fireman475   us
    • Trophy Junior  ‐    5
      #166
    Offline Fireman475
    • Bike: 2016 Trophy SE
    • City / Town: Southport, NC
    Reply #166 on: Feb 02, 2023, 10.16 pm
    Well, I'd like to post my experience with Crash Bars By Tralex.
    I only needed the rear crash bars as the previous owner had installed the front ones. After initial contact with Alexander, I made the purchase and he keep me well informed of the progress. After only a week and a half, the FedEx guy dropped them at my front door. Thirty minutes later, they are on the bike. The look great and appear to be very well made; hopefully, I won't be testing them anytime soon.
    Now, if this cold rainy weather would just move on by, I could go for a ride.
    Later,
    Darrell
    J. Darrell Bryant
    2016 Triumph Trophy SE
    2004 Harley-Davidson Sportster
    1980 Yamaha XS850 Special
  • Offline mappedFA   gb
    • Trophy Junior  ‐    1
      #167
    Offline mappedFA
    • Bike: Trophy SE & T120
    • City / Town: Stoke on Trent
    Reply #167 on: Feb 13, 2023, 01.47 pm
    Hello all! These bars look great! How would I go about getting a set? I can not find a site for Tralex -
    Many thanks!
    Last Edit: Feb 13, 2023, 02.03 pm by Trophy Moderator
