Author [NL] [FR] [ES] [DE] [SE] [IT] OEM Battery Brand  (Read 6058 times)
  • Offline STJIM   us
    • Trophy Master  ‐    680
    • #8
    Offline STJIM
    • Bike: 2015 TTSE ( Blue )
    • City / Town: West Michigan
    Re: OEM Battery Brand
    Reply #8 on: Apr 24, 2022, 05.32 pm
    OK, the plot thickens ....
    I re-checked the Deka catalog and the listing said :   1215 c.c.  2015 Triumph Trophy SE  ABS -  ETX14.  Their "ETX" batteries are all AGM batteries.
    So it looks this is an error on Deka's part.  I thought maybe Deka doesn't make a ETX 20 battery, but when I looked at their battery specification section,  they do also make an ETX 20 AGM battery.  But I'm certain the ETX 14 battery will work just fine.
    Last Edit: Apr 24, 2022, 06.24 pm by STJIM
    IBA #35372  Mile Eater Gold 8-2022
    BBG  5-2014  SS3K 9-2020
    Great Lakes 100 : 2011 / 2019 / 2022 / 2023
    2015 TTSE , 2008 Concours C-14
    1998 ST1100  1976 Moto Guzzi Convert
  • Offline STJIM   us
    • #9
    Offline STJIM
    Reply #9 on: Apr 28, 2022, 05.03 pm
    So, I received my new Chinese 14 AH AGM battery yesterday.  I put it on the maintainer overnight and this am the terminal voltage off the maintainer is 13.04 volts which is a little surprising - I thought it would be less.  I know my Fluke meter is accurate. I installed it and it does a fine job turning over the engine - seems about the same as the larger OEM size battery that it is replacing.
    I will post periodically how it is performing.  I'm not anticipating having any issues with thi slightly smaller battery.
  • Offline STJIM   us
    • #10
    Offline STJIM
    Reply #10 on: Aug 07, 2022, 03.33 am
    I think I know why Triumph speced a slightly larger batter than other bikes with similar size engines.  I think it's because of the radio.  I think Triumph ws concerned that an owner may play the battery when the bike isn't running and that might run the battery down too much with a smaller battery to the point where the battery might not be ble to start the baike.
    Not a problem in my case since I don't ever use the radio.
  • Offline STJIM   us
    • #11
    Offline STJIM
    Reply #11 on: Nov 20, 2022, 05.31 pm
    UPDATE :
    The ETX 14 battery has worked just fine starting the Trophy since I installed it a few months ago.  It's still installed in the bike and on the maintainer until next spring.  Then I'll see how good it spins the engine over at that time.  We got about 11 inches of snow the last few days, BTW.   The riding season is over for 2022.
    Last Edit: Nov 20, 2022, 05.39 pm by STJIM
