Author [NL] [FR] [ES] [DE] [SE] [IT] Ignition coil removal  (Read 348 times)
  • Offline Grubloon
    • Trophy Pro  ‐    234
    Offline Grubloon
    • City / Town: Altrincham, Cheshire
    on: Jan 31, 2023, 01.01 pm
    I'm trying to renew the spark plugs but I'm having trouble removing the coils, they are very tight and don't even want to rock back and forth too loosen, I've looked to see if anything in the search engine, but nothing found, my manual just says remove coils, no hints if they are tight to remove, so now getting a bit cheesed off, so any ideas on how too loosen them would be most appreciated, cheers.
     :187:
    Last Edit: Jan 31, 2023, 01.11 pm by Grubloon
  • Offline STJIM   us
    • Trophy Master  ‐    567
    Offline STJIM
    • Bike: 2015 TTSE ( Blue )
    • City / Town: West Michigan
    Re: Ignition coil removal
    Reply #1 on: Jan 31, 2023, 02.01 pm
    Mine were tight too when I did my valve adjust and plug replacement.
    Just take it easy - try to rotate them back & forth a bit and then pry upward by using a skinny wood stick .
    When I re-installed I applied some dielectric grease to the rubber boot that slips over the end of the spark plug.
    Good luck - just take it easy.
    IBA #35372  Mile Eater Gold 8-2022
    BBG  5-2014  SS3K 9-2020
    Great Lakes 100 :  2011/2019/2022
    2015 TTSE , 2008 Concours C-14
    1998 ST1100  1976 Moto Guzzi Convert
  • Offline Grubloon
    • Trophy Pro  ‐    234
    Offline Grubloon
    Reply #2 on: Jan 31, 2023, 06.05 pm
    Problem solved, used a tyre lever to gently lift the coil while pulling at the same time, used a thin wipe of rubber grease around the top part of the coil when I replaced them.
    The next bit of fun was removing the plugs, plug socket didn't like being pulled out, had to twist it to remove it, all done now.
    Thanks STJIM for your advice, I did take it very carefully. :821:
  • Offline STJIM   us
    Offline STJIM
    Reply #3 on: Jan 31, 2023, 11.25 pm
    Good to hear !!
