Author [ES] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [SE] [FI] [NO] Topic: Stuck brake calliper  (Read 1613 times)
Offline Iain
  • City / Town: Stornoway
« on: March 06, 2014, 11:09:30 pm »
What's the best thing for unseizing a stuck calliper? should I lube it with something after freeing it?
Honda VFR 2002
Sprint ST 2007
Sprint ST 2009
Sprint GT 2011
Trophy SE 2013
Offline Ernest T
  • City / Town: Salado, Texas
Re: Stuck brake calliper
« Reply #1 on: March 07, 2014, 01:38:01 am »
Your Trophy has a stuck caliper?  Take it to the dealer because there is something seriously wrong if a new bike has a stuck caliper.  Bikes that haven't undergone routine brake maintenance usually don't get stuck--even after many years of use.  If you follow the manual you should never get a stuck caliper.  I've restored several old bikes and broke the piston free by disconnecting the brake line and using air pressure, but beware it could shoot across the garage.  Once its free I'd remove the old seals, then clean it using new brake fluid.  If there is any stuck on gunk you can use something like simple green to get it out.  Any corrosion on the caliper or piston and they need replaced.  Once you have it clean, lube the new seals and install them. Coat the piston with brake fluid and insert it in the caliper.
Offline DonTom
  • Don & Tom in Gulin, China
  • Bike: 2013 TTSE & 9 others
« Reply #2 on: March 07, 2014, 07:31:09 am »
*Originally Posted by Iain [+]
A Triumph Dealer.
-Don-  Reno, NV
1971 Black BMW R75/5/* 1984 Red Yamaha Venture* 2002 Yellow Suzuki DR200SE* 2013 Blue Triumph Trophy SE*2016 Orange/Black Kaw Versy 650 LT*2016 Orange Moto Guzzi Stelvio* 2017 Gold/Black Harley FLTRU RoadGlide Ultra*2017 Zero 6.5DS* 2017 Zero SR13 w/Pwr Tank*2020 Energica SS9
