Author [ES] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [SE] [FI] [NO] Topic: Need a switched power lead for a FuzeBlock  (Read 2469 times)
Offline Padman63
  • Get er Done, Make er smoke
  • City / Town: San Diego Way, CA
« on: March 14, 2014, 12:50:42 pm »
Hello,
I am adding a FuzeBlock (see attached picture) underneath my seat on my TTSE so as I can add some lighting, etc. It has 3 leads, one is 12VDC that goes to the + battery, one goes to a ground and one that requires a "switched power source" Can anyone help me with a good way to tap into a reliable source under the seat perhaps near the fuses? Or would a better source be up front somewhere? Thank you!
« Last Edit: March 14, 2014, 12:53:15 pm by Padman63 »
2013 Triumph Trophy
2007 Honda Goldwing
2006 BMW R1200RT
2006 Harley Davidson Streetglide
2002 Harley Davidson Heritage Softail Classic
Offline BigD
  • City / Town: Columbus (Dublin) OH
Re: Need a switched power lead for a FuzeBlock
« Reply #1 on: March 14, 2014, 01:14:58 pm »
Power feed to top box
Power feed to the accessory outlet under left pillion seat
Tail light
Offline Padman63
« Reply #2 on: March 14, 2014, 01:44:45 pm »
thanks, I guess the wire to tap into would be red on the accessory cord?
2013 Triumph Trophy
2007 Honda Goldwing
2006 BMW R1200RT
Offline Ray_B
  • Bike: '15 SE (ex '13 SE)
  • City / Town: Central New Jersey
« Reply #3 on: March 14, 2014, 03:20:30 pm »
I used the GPS power plug under the left fairing as a source for switched power. The mating dongle from triumph is under $15 and can be used to fire a relay (or the fuzeblock trigger) that feeds your fusebox accessories directly from the battery. The advantage is you don't need to cut into the loom and all your farkles are independent of the TT electrical system.
« Last Edit: March 14, 2014, 03:27:33 pm by Ray_B »
Ray
Offline Padman63
« Reply #4 on: March 15, 2014, 12:35:17 am »
where can I get this mating dongle, do you know?
2013 Triumph Trophy
2007 Honda Goldwing
2006 BMW R1200RT
« Reply #5 on: March 15, 2014, 09:06:01 am »
The "mating dongle" is just a plastic moulded plug with two wires - ( + and - )
The plastic plug connects directly and neatly to the dedicated clean power supply socket
for the Sat Nav system, located under and behind the left hand mirror pod,
saving the need to cut and/or splice into any other wiring.
The other ends of the wires are bare with crimp connectors for connecting to your Sat Nav device ( or whatever ).
The Triumph Accessory Kit is Part Number A 9938122 and should be available to order from your Triumph Dealer  :028:
Offline Padman63
« Reply #6 on: March 15, 2014, 01:08:20 pm »
Aaaahhhh, thanks Coconut. I do already have that part A9938122 for use. I guess the "mating dongle" term through me off! b :008:
2013 Triumph Trophy
2007 Honda Goldwing
2006 BMW R1200RT
