Author [NL] [FR] [ES] [DE] [SE] [IT] Odometer reading slow  (Read 2235 times)
  • Offline tdragger   us
    • Trophy Master  ‐    605
    Offline tdragger
    • City / Town: Fredericksburg
    on: May 24, 2016, 07.16 pm
    I'd say that this is a first for me.  I just completed a Bun Burner Gold this past weekend and was surprised by how much the odometer was less than the GPS miles.  I've never had a bike that read less.  Most of the time the reading is higher.  Since I do a lot of long distance (Iron Butt Association) rides, I need the ODO to be more accurate.
    For this ride GPS showed 1572.2 where the bike showed only 1558.4.  It may not sound like much but it can be critical in an IBA ride.
    Can the ODO be adjusted via the DealerTool program?
    15 Triumph Trophy SE (2019 Iron Butt Rally, 2022 LDX Rally)
    16 Triumph Trophy SE (2021 Iron Butt Rally)
    IBA #609
  • Offline thumper
    • Trophy Pro  ‐    139
    Offline thumper
    • Naty von Ozirisz 1997-2011
    • Bike: '15 Trophy SE
    • City / Town: So Cal
    Re: Odometer reading slow
    Reply #1 on: May 24, 2016, 07.21 pm
    I don't know if the Dealer Tool will work for what you've asked, but if my math is right, the different of 14 miles over a 1,600 mile reading makes your Trophy's odometer 99.12% accurate.
    Are odometers usually more accurate than that?    :440:
    ATGATT--Because if you crash, the world is your belt sander
    Offline tdragger
    Reply #2 on: May 24, 2016, 07.36 pm
    I would agree that it is pretty accurate but I've never had one read slow.  It means that if I'm on an IBA run that requires 1,000 miles, I have to ride at least another 8 miles or so just to get the counter over 1k.  I'd rather it read 1% fast than 1% slow.
    IBA #609
    • Trophy God  ‐    10140
    Reply #3 on: May 24, 2016, 09.04 pm
    DealerTool can't be used to calibrate / re-calibrate the Odometer, ( or the Speedometer ),
    and I doubt the Triumph Dealer diagnostic equipment can either !
    ... and I presume "Slow" = Short / "Fast" = Long for the Odometer ?
    Last Edit: Mar 25, 2022, 11.28 am by Coconut
    Offline tdragger
    Reply #4 on: May 24, 2016, 09.19 pm
    Thanks Mr. C.  On my Rocket you can adjust the speedo/odo with TuneECU but TuneECU is not supported with the Trophy.
    I was hoping that DealerTool could make the adjustment.
    IBA #609
  • Offline DonTom   us
    • Trophy Master  ‐    2016
    Offline DonTom
    • Don & Tom in Gulin, China
    • Bike: 2013 TTSE & 9 others
    Reply #5 on: May 25, 2016, 03.00 am
    *Originally Posted by tdragger [+]
    I think you will find both are accurate.  GPS works direct, point to point and is near 100% accurate. The Bike's odometer takes curves and such into consideration where the GPS does not (regardless of MPH shown on you inaccurate speedometer).  But usually, the GPS will show the shorter distance but even that depends on variables as the point to point even changes in curves and such.
    GPS works differently than your odometer. Expect the odometer on the bike is more accurate than the GPS for actual distance on a road.
    If you want to compare both, you need to ride in a perfectly straight line between two points. Then both readings should match.
    -Don-  Cold Springs Valley, NV
    1971 Black BMW R75/5/* 1984 Red Yamaha Venture* 2002 Yellow Suzuki DR200SE* 2013 Blue Triumph Trophy SE*2016 Orange/Black Kaw Versy 650 LT*2016 Orange Moto Guzzi Stelvio* 2017 Gold/Black Harley FLTRU RoadGlide Ultra*2017 Zero 6.5DS* 2017 Zero SR13 w/Pwr Tank*2020 Energica SS9
  • Offline 2slowTrophy   us
    • Trophy Master  ‐    1441
    Offline 2slowTrophy
    • Bike: 2015 Trophy SE Blue
    • City / Town: Dallas TX
    Reply #6 on: May 26, 2016, 08.02 pm
    So if it show less miles than you have gone you will never come up short mileage on a IBA run.
    You will be safe with more miles showing on Google Maps than on your odometer.
    IBA # 59602
    One of the Founding Members of the Twisted Trophy's
    Offline tdragger
    Reply #7 on: May 26, 2016, 09.01 pm
    true.
    IBA #609
