Author [NL] [FR] [ES] [DE] [SE] [IT] Trophy with limp mode/traction control light problem.  (Read 7818 times)
  • Offline Trixies dad
    • Trophy Member  ‐    27
    Offline Trixies dad
    • Bike: TTSE
    • City / Town: Didcot
    on: Aug 08, 2016, 06.57 pm
    Hey folks.. So I have a problem..
    My 2013 trophy has been going into limp mode with TTC disabled coming up on the display plus the TC light and EM light, bike will cut power totally then begin revving constantly to 6k rpm. Sometimes I get marginal power back but barely revving and just able to do 60mph
    Fault codes come up are P2127, P1135, P1574
    My dealer has just changed the twist grip assembly believing this was the problem to no avail.. Any ideas? I'm getting tired of the bloody thing trying to dump me on the ground.. Thanks in advance Ces
  • Offline atrophy   us
    • Trophy Master  ‐    522
    Offline atrophy
    • Bike: 13 Trophy SE silver
    • City / Town: SW Ohio
    Re: Trophy with limp mode/traction control light problem.
    Reply #1 on: Aug 08, 2016, 08.44 pm
    P1135   Traction control prevented due to ABS problem
    P1574   Cruise control prevented due to other malfunction condition
    P2127   Twist grip position sensor 2 short circuit to ground or open circuit
    I would guess from the above the dealer did not install the new throttle correctly and I would look at the abs sensors and wires.
    Good luck
    2016 Tiger 800XR  Black
    2013 Trophy Lunar Silver
    Exclusively using recycled electrons since 2004
    IBA 24605
  • Offline nigelrtaylor
    • Ex Member
    • Trophy Member  ‐    56
    • Ex Member
    Reply #2 on: Aug 09, 2016, 11.46 am
    Mine was doing that but no problem codes being captured. Turned out it was a bit of metal swarf of the rear abs sensor
    Offline Trixies dad
    • Bike: TTSE
    Reply #3 on: Aug 09, 2016, 05.59 pm
    Thanks guys .. I'll have them look when i can get it there .. was hoping to ride it there today but the damn just sat and revved it's nuts off when i started it .. so I'll have to trailer it this week ..
    • Trophy God  ‐    10273
    Reply #4 on: Aug 11, 2016, 06.35 am
    Did you have the same DTC's before the Dealer changed the Twist Grip, or only after ?
    I think that P2127 "Twist Grip position sensor 2 short circuit to ground" is the most relevant,
    and the other two are probably thrown up as a result of it,
    so once the Twist Grip problem is fixed then the other two "faults" will also clear.
    Id the same DTC's were present before the Twist Grip was changed,
    then it may be that the fault lies somewhere else in the circuit.
    I don't have access to the wiring diagram right now, but other similar problems have been
    as a result of "tight" wiring around headstock causing wires to be pulled out from either
    the switches and controls on the handlebars, or the base of the Ignition switch assembly.
    Keep us posted !
    Last Edit: Jan 07, 2021, 07.38 pm by Coconut
    Offline Trixies dad
    • Bike: TTSE
    Reply #5 on: Aug 11, 2016, 06.57 am
    Good morning Coconut .. I have the exact same fault codes as before mate .. also the exact same symptoms .. Bike goes down Friday to the dealers ..
    Reply #6 on: Aug 11, 2016, 04.42 pm
    Sounds like the short circuit is somewhere prior to the part they changed then !  :084:
    I'm sure they will find and fix it though.
    I look forward to hearing you're back on the road next week
    and finding out exactly what was wrong !
    Last Edit: Jan 07, 2021, 07.37 pm by Coconut
    Offline Trixies dad
    • Bike: TTSE
    Reply #7 on: Aug 11, 2016, 05.26 pm
     :084: Here's hoping mate ..  :028: .. I'll drop a line on here when i get the big girl back .. I almost traded her the other day for an explorer but had such a good ride home I decided against it up to the point it went back into limp mode again fuuuuaaacckkk  :233: :125: ..  Luckily I have my wife's Tiger 800 to get to work on  :028:
