Author [ES] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [SE] [FI] [NO] Topic: LED front turn signal bulb?  (Read 1381 times)
Offline rpeters549
  • City / Town: Lowell, Or
« on: October 20, 2018, 06:37:29 PM »
Thinking of swapping in quite bright LED replacements in the mirror housings.  At around $10 each though, not worth it if I get the rapid blink.  Don't want to use resistors/load balancers, just the bulbs.  Anyone done this?  Does blink rate stay the same or get rapid?
Year round rider here!
Offline Jeffb
  • City / Town: Columbus OH
Re: LED front turn signal bulb?
« Reply #1 on: October 20, 2018, 07:18:55 PM »
I had to use resistors, but I think you can now find some led bulbs with internal resistors. You'll need resistors somewhere in the system, as it was engineered for incandescents.
Offline Rick505
  • City / Town: Albuquerque, NM
« Reply #2 on: October 21, 2018, 03:46:42 PM »
I haven't checked but is there an electro-mechanical flasher on the bike originally?  If so, get an electronic flasher and no resistors necessary.  Heck I did this n a 2008 Royal Enfield Bullet without issue.  Just not sure how much of the "Computer" controls the flashers.  I went with LED's on the Enfield just to reduce power consumption BTW.
« Reply #3 on: October 21, 2018, 09:27:34 PM »
There is no separate Flasher Unit on the Trophy - this function is controlled by the Instrument pack.
Smiles are infectious,and they are FREE,
so if you see someone without one, give them one of yours :-)
Offline rpeters549
« Reply #4 on: October 22, 2018, 12:16:39 AM »
Might just try it.  Especially if I use brighter LED's that draw a tad more voltage anyway...
Offline darmah59
  • City / Town: SALINE
« Reply #5 on: October 22, 2018, 02:31:14 PM »
Be careful, the blinking is controlled by the resistance of the bulb, might make the indicators fail.
Offline thumper
  • Naty von Ozirisz 1997-2011
  • Bike: '15 Trophy SE
  • City / Town: So Cal
« Reply #6 on: October 23, 2018, 05:45:54 AM »
I did this a couple of years ago, and they're still working 100%.
https://www.triumph-trophy.com/index.php/topic,5604.msg70360.html#msg70360
My job does require resistors, but they're extremely easy to mount on a Trophy.    You'll have to find out which LED bulbs have replaced the ones I used, as they're no longer available on Amazon.
ATGATT--Because if you crash, the world is your belt sander
Offline AZBob
  • Wubalubadubdub!
  • City / Town: Chandler, AZ
« Reply #7 on: October 29, 2018, 06:15:45 PM »
You will absolutely need resistors, there isn't an LED set made that draws enough power to get the blink rate correct. There MAY be some that have resistors incorporated, but I doubt they'd fit since the space behind the mirror isn't the greatest, and the resistors need to dissipate the heat, so they'd probably be exposed to the wiring in the mirror pod, which may melt something.
If you DO decide to wire in the resistors, I tested out a several LED amber bulbs a little while ago: https://www.triumph-trophy.com/index.php/topic,8184.0.html -- I'm still running the ultra bright ones from my tests without incident.
2014 Triumph Trophy 1200 SE
2013 Honda CB1100
